yellow1
Active Member
Need some advice here. Last summer my Demon started shutting off while driving normal after about 20 minutes. at the time I was running MSD 6al box with aftermarket distributor, and 40 year old wiring! It would act like the switch was turned off while under power,you know backfiring also. I cranks right back up,then may or may not do it all over again. So this summer I replaced the wiring harness, bumper to bumper with a painless wiring kit, new mallory coil, HEI type ignition, new ignition switch, everything has been replaced. I drove it about 200 miles after all that it started doing it all over again. Not supposed to need a ballast resistor so I do not have one. In my mind I am thinking coil overheating , but it cranks right back up. Has anyone ever seen this before?
