I just installed and aimed a pair of NOS #6012 headlight bulbs. Same brand, same number. One is noticeably brighter. Why? I am thinking of switching them side to side to see if that makes any difference. All wiring is original.
Bad Ground on the Passenger Side Headlamp, the dim one.
My first thought would be ground.
A dirty / corroded ground can do that.
Do an Ohms test on both bulbs also, see if they are at least close to the same.
(a new bulb does not mean it is good)
If the headlight switch is good...2 things, bad wire on the that bank or bad bright switch on the floor. Bypass it and see what you get. Use some alligator clips.Hi/Lo does not make a difference. No other dead bulbs.
You are correct.I put the OEM style bulbs back in because I thought I would be avoiding other problems. Other posts on this forum said that newer style bulbs use more amps and the original wiring was not up to that.
