Bill I really have to disagree with ya here
jh, if you still have the typical factory wiring, and you've probably read some of my ranting and raving about the pitfalls of the bulkhead connector, you might consider doing it "different"
At the very least, if you DO decide to tap into your existing panel, at least yank the bulkhead connector apart and make sure it's in OK shape first
But I'd rather see you add a through wire (grommet) from the starter relay with a nice big breaker, 20A or so. If you are considering adding anything else, like stereo, make it that much larger. But in any case, no 12 or so. You can use a relay in there triggered from any accessory tap on the fuse panel so it's live with key on. When you are tootin' down the road with that AC on "full" you are operating a fairly big fan motor, plus the compressor clutch, and you sure don't want to be smokin' the factory harness.
Now having said that, there are PLENTY of these on the factory stuff, but these girls are getting OLD, and more and more folks are having problems directly related to the bulkhead connector.
Just food fer thought
