Only runs in start
412 Stroker
Green Bay, WI
Hello:
New to this forum, not new to mopars, here is my problem, Freshly rebuilt 360, now a 412 stroker, in a 1974 duster. Mallory 6AL ignition, & coil, first time I am firing it up, today, will not run unless ignition is in the start position, i am NOT using the ballast resister, I might have found my answer already not tried it yet though, apparently there is ign1 and ign2 on mopars, i have my 6AL hooked up the the old brown wire that went to the coil just like it says in the manual, according to the schematic i found on another web site, that wire only has 12 volts in the ign2 (start) position, there is a blue wire that went to one side of the resistor and that wire is ign1 which has voltage in both positions anyone here have an opinion?? I had the factory electronic in it before i put in the rebuilt motor. thanks for the help....
Yep.
If you leave all the "stock" wiring and pulled the ballast resistor then you need to connect the 2 wires it went to together.
I think I'm right guys..........what say you?
Welcome.
Jim
Yep.
Welcome.
Jim
This is what I,ve done as I,m running my battery in the trunk and also have the ON/OFF kill switch.
I wanted to keep a stock look so I pulled the ballast and soldered a piece of 16 ga from terminal to terminal on the back side the re-installed it. Just make sure it doesn't short out on the firewall.
Thanks to all your help, I connected the blue and brown wires and it fired up and stayed running, now if i could only get it timed correctly...... thanks again.
tl
