71DartGuy
This past weekend one of my friends told me about an old trick he used to use on an open rear to help it grip a little tighter. He told me that he used to pull out the spider gears and put extra spacers between the gears and the case. He said it would make it harder for the gears to turn and in turn make it grip a little tighter. I hope I explained this well enough. Has anyone ever done this to an 8.75? I have it out of the housing and figured if it works I may do it while its on the bench. It may be a while til I can afford a sure grip with some steeper gears.
