I already have the .039" gaskets ordered and I see your point on the quench. Being serious here, what would be the gain of advancing the timing 2*? More cylinder pressure? I am not an expert in this area and like to learn.
I'ma big fan of tight quench. My pistons were up,all over the place. I found the KB-107s bang on as to compression distance. But I found my rods were not all exactly the same length, and the reground crank throws were out a bit, and my decks were out a bunch. In the end, after a days worth of shuffling parts, I got the deck-heights evened up to .005 from the shortest to the tallest, but I hate expressing such a crappy number that way. I'm much happier saying they are out of the hole; .0025 +/-.0025 See doesn't that read much tighter. It's like buying something for 1.99 instead of 2.00. I mean who are we kidding.
So with the .039 gasket, I'm running a quench of .034 to .039, oops I mean .0365,+/-.0025! See how that works? My combo has never put the piston into the head. I ran it with the .029 gasket as well with no contact. I'm not doing the math on that cuz it sounds scary.
Tight quench is said to promote all kinds of benefits, to which some I can attest. With a HE2430 cam and a list 1850 carb(600vac,sec), and on the AG, I was able to get my S into 32mpgUS with no ill effects.And with a 3310(750) it went 12.9 with 3.55s(same cam). I like quench.
Of course I have no basis of comparison to say that .040 or .050 would be any worse. This is just how my combo came together, and I went with it.And I'm glad I did.
Then there's the extra compression with the .010 . This is worth a bit over 2 cc. You do the math.....
But more important is the earlier closing intake. This will trap a bit more mixture, and pump up the torque a few ftlbs right at the starting line, where the 340 needs it.And it will be noticeable any time you are running on the short side of the torque curve, namely idle to 3000 or so. Yeah you will be stealing it from the topend, but where will your engine be spending most of it's time.
I can guarantee you, in the long term, If you are a streeter like me,you will be happier with the extra at the bottom, than the extra at the top.
That's my thinkin an Ima stickin 2 it.
Well almost. I'm running a Scr/Dcr of 10.67/8.53 with a 360, an on 87E10. Your shorter stroke 344.5, could probably push a Dcr .2/3 higher than mine,on 89, and maybe .4/.5 on 91. That's the beauty of setting it up on the .029 gaskets. If you just can't tune for 91, then slide in the .039ers. I thought I was pushing the limits with my combo when I ran crs of 10.82/8.85, but not so. The only time I ran anything but the 87 was for the few track runs; 4 with the 223* cam, and 4 with the 230*.
Having BS'ed my way this far, I should add that this is how my combo fell together. I certainly wouldn't recommend that you spend a ton of green chasing perfection.On the street I doubt you would notice the performance difference in .3 or maybe even .5 in Dcr difference. I mean it might be the difference in spinning the tires 75% of the way through second gear or 50%.I mean either way, you will be speeding with 3.55s!
