Original engine or not?
General Discussion
  1. Backally
    Backally FABO Gold Member FABO Gold Member
    575
    313
    Sep 4, 2011
    Wisconsin
    Local Time:
    1:56 PM
    C24780A5-2454-471E-9439-13658629C80A.jpeg i see threads about people looking for the original engine to their car. I got a 340 engine in a 70 Duster. By looking at the numbers on the block how can I identify if it was the original engine? And from what I read there should be numbers on the rt side of the block but mine doesn’t.
    Thanks
  2. dadsbee
    dadsbee FABO Gold Member FABO Gold Member
    1,101
    2458
    Nov 25, 2020
    Penetang, Ontario
    Local Time:
    2:56 PM
    I can see that the pan rail is VIN stamped from here...
    • Agree Agree x 1
    • Dartswinger70
      Dartswinger70 Catch a wave youll be sittin on top of the world
      3,393
      1811
      Sep 20, 2005
      Southeastern Pa.
      Local Time:
      2:56 PM
      There is a machined pad right under that hex "block drain plug" if you sand the paint down there should be a series of numbers that include a VIN sequence. i also think there may be another pad under the LF cylinder head...or maybe that's Chevy:) dern it I'm gettin old memory is foggy:)
      • Thanks! Thanks! x 1
      • Backally
        575
        313
        Sep 4, 2011
        Wisconsin
        Local Time:
        1:56 PM
        Ok, had some grease on it and I didn’t see it from my angle. It’s not the original, is there a way to see what it came from?
      • Alaskan_TA
        Alaskan_TA Well-Known Member
        6,104
        4635
        Nov 12, 2004
        PA
        Local Time:
        2:56 PM
        We can try.... Can you get a clear closeup photo of the number and post it?
        • Backally
          575
          313
          Sep 4, 2011
          Wisconsin
          Local Time:
          1:56 PM
        • cosgig
          cosgig MoBro Inc. FABO Gold Member
          11,708
          5186
          Jul 20, 2008
          Pinckney, Michigan
          Local Time:
          1:56 PM
          2 is the model year...1972
          B is the manufacturing plant...Hamtramck Mi
          The last 6 are your sequential build numbers, which should match the last 6 digits of your dash VIN, fender tag VIN, and body stampings
          • cosgig
            11,708
            5186
            Jul 20, 2008
            Pinckney, Michigan
            Local Time:
            1:56 PM
            Now, look on the front of the motor, right under where the drivers side head meets the block, there will also be numbers there. Assembly date of the motor, displacement, fuel designation, and a couple other numbers. Then, correlate all that with the casting number and casting date of the block. You should be able to say it was cast on.....date, was assembled in ......date, it’s a .....displacement motor for car 123932
          • toolmanmike
            toolmanmike Moderator Staff Member FABO Gold Member
            61,526
            50137
            Jan 18, 2006
            Iowa
            Local Time:
            1:56 PM
            That block sat around the warehouse a while before it was machined and installed. July 70 for 71 model year.
          • Dartswinger70
            3,393
            1811
            Sep 20, 2005
            Southeastern Pa.
            Local Time:
            2:56 PM
            Yeah there is "numbers matching" and "period correct" for a replacement engine etc. I would think the latter is all based on the date of the block.
            • Agree Agree x 1
            • Backally
              575
              313
              Sep 4, 2011
              Wisconsin
              Local Time:
              1:56 PM
              Looks like HM 340 R 36580 206. Not sure if you can see them in the photo
            • cosgig
              11,708
              5186
              Jul 20, 2008
              Pinckney, Michigan
              Local Time:
              1:56 PM
              I can’t make out much besides the 340P, and a few numbers. The P stands for premium fuel, as most 340 blocks called for. There’s an assembly date in that somewhere, but all I have is my puny little phone screen to look at it with.
            • harrisonm
              harrisonm Well-Known Member
              3,509
              3786
              Jan 16, 2005
              Topeka, KS
              Local Time:
              7:56 PM
              True. I have read that as a rule of thumb, most matching number parts (including the engine), should be dated no more than 2-3 months before the car's build date. BUT that exceptions could occur. I've read many accounts where dates on parts would be well outside that 2-3 month period. I always wondered if judges accepted those exceptions, or if the owners struggled to prove it was the car's original part.
              • Agree Agree x 1
              • cosgig
                11,708
                5186
                Jul 20, 2008
                Pinckney, Michigan
                Local Time:
                1:56 PM
                I had a 68 cast 383 that didn’t get assembled until 1971, I always wondered what happened to that block, must’ve been waaaaay back in the corner.
                • Agree Agree x 1
                • harrisonm
                  3,509
                  3786
                  Jan 16, 2005
                  Topeka, KS
                  Local Time:
                  7:56 PM
                  LOL. Or maybe waaaaaaaaaay back in the corner under a pile of seat covers made from 'Rich Corinthian Leather'.
                  • Agree Agree x 1
                  • toolmanmike
                    61,526
                    50137
                    Jan 18, 2006
                    Iowa
                    Local Time:
                    1:56 PM
                    I just bet the warehouse didn't rotate their inventory. FILO (first in, last out) They just keep filling the empty space in the front of the bin with new castings.
                    • Agree Agree x 2
                    • MoparMike1974
                      MoparMike1974 FABO Gold Member FABO Gold Member
                      3,405
                      2699
                      Jun 16, 2017
                      Maryland
                      Local Time:
                      2:56 PM
                      The 340 in my swinger came from a 72 challenger and it was cast in 70. They just used what was on hand and some may have been pushed to the back like mentioned. So casting date will get you in the general area but the vin and other stampings tell the true story.
                      Those numbers on the front of the engine can be hard to read. They are usually so shallow that paint fills them in.
                    • cosgig
                      11,708
                      5186
                      Jul 20, 2008
                      Pinckney, Michigan
                      Local Time:
                      1:56 PM
                      I know, right? I always say, don’t do something you don’t want to be known for. Instead of being a badass like Kahn, Ricardo will always be known for his love of the “finer” things, and for that parrot he had, what’s his name?....Tattoo?
                    • harrisonm
                      3,509
                      3786
                      Jan 16, 2005
                      Topeka, KS
                      Local Time:
                      7:56 PM
                      Tattoo was played by Hervé Villechaize. Did you know that he built a large complex of apartment buildings designed specifically for small people. Everything was sized and engineered for the wee people. And best of all, he did not charge them rent. He called them Stay Free Mini Pads. LOL!!
