Our radiators carry about the same PSI as a can of coke
"The same?"
The article says...........:
"Specifically, a refrigerated can of 7UP® contains 210 kPa of pressure. On the other hand, Pepsi-Cola® contains 276 kPa at approximately 16 °C. Lastly, a can of Coca-Cola Classic® at 34 °C has an internal pressure of approximately 380 kPa. These numbers came from employees of the soft drink companies themselves."
You convert 380kPa to something I can understand works out to about FIFTYFIVE psi give or take
None of my cooling systems run anywhere near that!!
I always pictured in my mind the pressure in a cooling system could really blow things apart, I guess I overestimated the image I held. Here is another trivia note from the internet:
The Pressure That Soda Exerts on a Bottle
If you leave a glass of soda out, it will quickly lose its carbonation and go flat. The carbon dioxide gas must be forced into the soda at pressures up to 8,300 kilopascals, or 1,200 pounds per square inch. The finished soda doesn’t exert that much pressure on the bottle, though. At room temperature, the pressure in a bottle of soda is somewhere between 276 and 379 kilopascals, or 40 to 55 pounds per square inch. Heat makes gasses expand, increasing the pressure, so a bottle of pop in a hot car can get as high as 689 kilopascals, or 100 pounds per square inch.
Plastic Bottle Design
Most two liter bottles are made of polyethylene terephthalate plastic, or PET, and designed to hold carbonated beverages. The thickness of the plastic and the shape of the bottle both contribute to its resistance to bursting. Quality control measures include pressure testing, as well as checking for leaks and cosmetic flaws. Most two liter bottles begin to fail at pressures around 1,034 kilopascals, or 150 pounds per square inch. The pressure at which the bottle will burst is more than it would normally encounter during packaging or normal use.
Did I ever experience that as a young kid! I remember one very hot day when my mom had me open a can of Ginger Ale for her as she was driving her brand new Plymouth Fury.
This was before pop tops (remember the little hole when you first punctured a can with a can opener?) and that internal pressure turned that can of Ginger Ale into "Old Faithful".
When the pressure finally equalized there was Ginger Ale dripping everywhere off of the headliner. Boy, was that ever a sticky Fury.
