1. Go Mango
    Go Mango Never enough beer...
    834
    1402
    Jun 3, 2018
    Avon, Indiana
    Local Time:
    10:05 PM
    Ok, all you super genius guys, I gotta get my spring out with the pedal assembly installed in the car.
    The new clutch requires that I remove it.
    Is there a really easy way, or should I just cut the S.O.B.?
    Fact is that I've got a really bad hernia, and don't have surgery until 7/22, so I'm a little bit physically impaired right now.
    REALLY appreciate any help I can get.
    Murph
  2. RustyRatRod
    RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
    79,157
    57450
    Jun 7, 2010
    Georgia
    Local Time:
    10:05 PM
    If you can get some brake spring pliers in there, that'll do it.
  3. Go Mango
    834
    1402
    Jun 3, 2018
    Avon, Indiana
    Local Time:
    10:05 PM
    Thanks Rob! I was counting on you to respond.
    I dont have any, but its sure as hell worth a try.
  4. K.O. SWINGER
    K.O. SWINGER Meeting in the alley since 1976
    2,321
    1986
    Nov 18, 2010
    oregon
    Local Time:
    9:05 PM
    if I recall someone said something like depress the pedal then put washers between the coils or something of that nature it sounded like a pretty good idea to me. Just keep your mouth closed and safety glasses on.
    • Agree Agree x 6
    • Go Mango
      834
      1402
      Jun 3, 2018
      Avon, Indiana
      Local Time:
      10:05 PM
      I've seen that done, but its really difficult with the pedal assembly still installed. I thought I'd see if anyone has a better idea.
    • Go Mango
      834
      1402
      Jun 3, 2018
      Avon, Indiana
      Local Time:
      10:05 PM
      Im telling you, im not a bit afraid to cut it. This has gotta happen in the next 4 days, because Saturday is when I'm going to have help putting it back together.
    • Go Mango
      834
      1402
      Jun 3, 2018
      Avon, Indiana
      Local Time:
      10:05 PM
      The old lady is wanting her garage back, and recovery from surgery is gonna be a month.
    • Alaskan_TA
      Alaskan_TA Well-Known Member
      6,132
      4688
      Nov 12, 2004
      PA
      Local Time:
      10:05 PM
      I have driven a few cars pals own with the clutch types that require that spring be removed.
      They wanted a second opinion.....
      Mine agreed with theirs, they suck.
      Can you return it and get an OE type?
      I would.
      • Thanks! Thanks! x 1
      • Agree Agree x 1
      • Go Mango
        834
        1402
        Jun 3, 2018
        Avon, Indiana
        Local Time:
        10:05 PM
        I'll get Dan Brewers opinion. Not doubting you a bit, but I've got nerve damage to my left knee.
        Already traded in my 5 speed truck for an auto. Hate to give up shifting the dart also.
      • Go Mango
        834
        1402
        Jun 3, 2018
        Avon, Indiana
        Local Time:
        10:05 PM
        Now that I've thought about it (for 2 minutes), you're probably right. Maybe I'll drive to Ohio tomorrow.
      • Alaskan_TA
        6,132
        4688
        Nov 12, 2004
        PA
        Local Time:
        10:05 PM
        I ordered a new setup for one of my cars from Brewers about a month ago, picked it up at Carlisle.
        I did mention that I wanted the stock type that keeps the spring & I went with Dan's recommendation.
        Since you have a bad knee.... the cars I drove with the alleged 'newer is better, just buy it and remove your spring' setup required a LOT more leg power.
        Odd release / engage points too, PITA to drive overall.
        • Agree Agree x 3
        • Alaskan_TA
          6,132
          4688
          Nov 12, 2004
          PA
          Local Time:
          10:05 PM
          Also.... I have nerve damage in both knees, but the test drives I mentioned occurred before that when I had healthy knees.
          Driving those cars with the modified clutch setup still sucked.
        • Johnny Dart
          Johnny Dart Well-Known Member
          8,327
          3147
          Nov 30, 2006
          So Cal
          Local Time:
          7:05 PM
          You keep the spring with the old 3 finger borg warner clutch.
          F**k that noise, get with the times, lose the spring and get a diaphragm clutch. Works like butter, without that weird feeling the spring gives. Night and day difference. Good luck !!!
        • RustyRatRod
          79,157
          57450
          Jun 7, 2010
          Georgia
          Local Time:
          10:05 PM
          If you read what he posted, that's what he has and why he wants to remove the spring.
        • Johnny Dart
          8,327
          3147
          Nov 30, 2006
          So Cal
          Local Time:
          7:05 PM
          If you read, the conversation took a turn towards the "stock type" (borg warner) clutch, and keeping the spring.
        • RustyRatRod
          79,157
          57450
          Jun 7, 2010
          Georgia
          Local Time:
          10:05 PM
          OK thanks. I missed since you didn't quote it. My good eye would fall out if I tried to read everything.
        • SGBARRACUDA
          SGBARRACUDA ROY FABO Gold Member
          21,438
          9935
          Dec 7, 2006
          PLANT CITY FL. and PERRY GA.
          Local Time:
          10:05 PM
          large washer trick works if you can find enough of them. Install them with the pedal all the way out. When press the pedal in with washers in place, it should give you enough play to remove it
          • Kendog 170
            Kendog 170 Let the boy go !
            2,361
            1689
            Mar 10, 2016
            Tewksbury Ma.
            Local Time:
            10:05 PM
            I may be wrong but I did the washer thing. If you disconnect the rod at the pedal then push it will go to the floor and stay there (I think lol) then stuff it full of washers and pull it back ? it's been a while but I did it by myself .My memory sucks ! lol
            • Like Like x 1
            • Daves69
              Daves69 Well-Known Member
              6,034
              4555
              Feb 20, 2011
              WestOfChi
              Local Time:
              9:05 PM
              Not that I've ever needed to, but I believe you would want the pedal at center where the spring would be extended furthest to insert washers. Then all the way to the floor to remove the spring from the pins.
            • Kendog 170
              2,361
              1689
              Mar 10, 2016
              Tewksbury Ma.
              Local Time:
              10:05 PM
              Now I remember. I tapped a screw driver between a coil then slid in a washer and removed screw driver and repeated until I got it off.Probably around 8- 10 washers ?
              • Agree Agree x 2
              • Like Like x 1
              • SGBARRACUDA
                21,438
                9935
                Dec 7, 2006
                Local Time:
                10:05 PM
                Yeah I’ve never had to remove the spring while the pedals were in the car. But done it several times when pedals were out to rebuild them. By the way, i found a easy way to reinstall it. Use a floor jack hook the spring on the front axle, hook the other end on the bar below the plate. Jack the handle until the coils are apart to slip several thick washers in the coils, release the jack spring will stay extended, now install the spring on the pedals and start removing the washers with vise grips until they are all removed.
              • Kendog 170
                2,361
                1689
                Mar 10, 2016
                Tewksbury Ma.
                Local Time:
                10:05 PM
                This How to Install Overcenter Clutch Spring in the Car
                I took my bucket seat out for comfort to back and knees.
                • Like Like x 1
                • Backally
                  Backally FABO Gold Member FABO Gold Member
                  576
                  315
                  Sep 4, 2011
                  Wisconsin
                  Local Time:
                  9:05 PM
                  I didn’t have washers, so ran a bunch of short drywall screws in instead. Anything to keep the spring stretched out will work
                • SGBARRACUDA
                  21,438
                  9935
                  Dec 7, 2006
                  Local Time:
                  10:05 PM
                  • Like Like x 1
                  • 19DART66
                    19DART66 Well-Known Member
                    308
                    145
                    Nov 19, 2008
                    Ballston Lake NY
                    Local Time:
                    10:05 PM
                    I disconnect the clutch linkage from the pedal, then remove the "C" clip on the brake pedal side that keeps the clutch pedal from sliding out. Then slide the clutch pedal out enough to clear the pedal stop, lift the pedal up and the spring will come right out. push the pedal back down, slide it back inplace, put the clip back on, hook up the clutch linkage and done, or you can do the same to put the spring on.
                    • Like Like x 2
                    • Agree Agree x 1
