la67DartGT
- Joined
- Mar 18, 2008
- Messages
- 74
- Reaction score
- 0
I'm in the midst of the 4 speed swap, and was swapping out the pedal assembly. As I was doing this, I discovered the brake pedal on the 4 speed setup was sticky, so I took the assembly apart to free up the brake pedal. When putting it all back together, I had the most irritating time putting the over center spring back on. I did finally figure it out, but as i play more with it, it really seems like this spring doesn't do anything. Is the over center spring really required? Can I remove it and leave it out?
- Don
- Don
