Overlap Triangle
Danny Bellmore
Maine
Is there anyone who knows how to center the overlap triangle over TDC?
Post your cam numbers and I can tell you where the ICL needs to be to center the overlap triangle.
So seat to seat if you have it, LSA/ICL, @ .050 numbers and lift.
I will give you what I have from the cam card.
Comp Cams 20-718-9
Gross Valve lift (in 654) (ex 655) add 1.6 rocker arms.
Duration @50 (in 269) (ex 276)
Lobe Lift (in .436) (ex .437)
Valve Timing @50 (in open 45) (in close 77)
(ex open 81) (ex close 48)
Lobe seperation 106
Comp Cams 20-718-9
Lobe seperation 106
I'm going to assume that Comp called for a 102 ICL. So 4 degrees advance.
To center the overlap triangle you need to install the cam at a 105 ICL.
Thank you for your help. It is much appreciated.
Comp does not specify what it called for, I have it in at 104 currently. I am just trying to get my combination to work optimally with what I currently have.
At 104 you are close enough to let it go. I wouldn't change it. Plus its damn hard to find one degree. You may end up with the cam a bit retarded.
lol yeah, I’m not politically correct.
BTW, i assume the overlap triangle would be centering the valve events so they happen with tdc right in the center? Just a guess.. had never heard of it before.. kind of curious where my cam would land but it will just make me overthink and go nuts over something that doesn't matter at this point :)
Go to mgispeedware.com and click on the camshaft calculator.
You can enter your cam numbers and look at the graph and see what you have.
Well, I guess I will need a new cam and lifters. I pulled the intake off today to mill for more clearance for the valve covers and it appears that I have a bad lobe and another starting to wear. Brand new Comp cam and brand-new Bam bushed lifters.
Ouch!! What happened??
I'm not really sure what happened here. I cut all my oil filters open, and I found bronze the middle of the summer. I pulled the Milodon shaft and gear and it was pretty much chewed up. I replaced the gear with one from Comp. I flushed the system as best as I could.
The good news is if you like the cam it can easily be welded and repaired.
I’ve never run that style of lifter but I’ve been told they are very sensitive to any dirt. Maybe some of that gear found its way past the filter and killed the bushing.
That’s a damn shame for sure.
I am currently starting from scratch. I will be bumping up my compression and would like to get a custom ground cam for my application.
Who would you recommend for designing a cam?
Damn that sucks sorry. Can you tell me if it’s a needle bearing axle or a bushed axle lifter? Either way it definitely stopped rolling.
pardon my ignorance...
what is an Overlap Triangle?
See the image above for a visual, but the overlap triangle is the time the exhaust valve hasn’t closed yet, and the intake has started to open. Centering the triangle is just moving the cam around to get those events to happen on the same side of TDC. In the pic above the triangle is NOT centered.
Post your view, stroke, rod length, compression ratio and at what RPM you want peak torque and peak power and I’ll run some numbers.
Also car weight and converter stall speed. And header size.
