paint help needed
LITTLE LUKE
Active Member
JERSEYVILLE,IL
need to know current paint codes for a1964 barracuda gold triedcross referance codes for aa1 /ditzler ppg 22461 as well as severl others when mixed was silver need to current code and brand thanks for heip
I was in contact with a company that could mix factory paint as Chrysler used. In this case Dupont. It was spot on. Here is different manufacturers codes for gold.
the chrysler code DT6182 napa has tried and it comes up silver was told by laysons old codes are not much use what company wre you in contact with thank you
