tomt966
I'm trying to "clean up" stone chips on my car. I don't make any claim to be a body/paint guy. I cleaned out around the chips with filler and smoothed the surface with 180 - 320 - 600 - and finished with 1200 grit dry paper. I can't compound out the whirls left from sanding in the areas around the damage. I compounded with a medium grit and tried straight line and circular motions. Should I go to 1600 or did i "f" it up and just leave it alone? How many coats of brushed on touchup should I apply before compounding & waxing the damaged areas? Thanx for any info....
