True, the better paints do use better resins. And it's also good to get more than enough for what you need, just because the stuff, (special effects like metallic and micas) can be very tough if not impossible to match. That's why the chromaflair paints, those are the color change ones that are not only expensive to buy, they are impossible to fix. Oh, what I said about the resins, there are only so many materials out there for paint making, the difference is in the resins. The only "exotic" pigments are the chameleon/chromaflair. One reason those are expensive is that is whats used on money. See the seal on paper money? That is the chromaflair/chameleon flop. Just to buy and store the stuff you need to be bonded from the government to make sure you are legitimate. Place I used to work at got all sorts of micas and xirallics as samples. Well, I got to take them home when the shelf life expired. The stuff is made from mica....same as sand. Whats the shelf life for sand? LOL. Ok, anymore and I will babbling, if not already.
Great statement!!! As for Nason single stage,they fade with time. If on a crazy budget,check out www.TCP Global.com. Older PPG mixes. The Crossfire Napa is sweet, also.
