Hi, I am going to redo the dash frame on my cuda and although practice makes perfect I dont want to do it twice!!LOL so I thought I would ask some ??? before I started. It is blk and in decent shape, but could use a repaint, so I am going to rattlecan it. Obviously I have to give her a bit of a scuff, so what are the suggestions on grit for the sandpaper, as well as the type or rattlecan paint to use. Also should I primer after scuffing and then scuff again?? Also there is some minor surface rust on the underside, should I sandblast that, or dont worry about it?? Like I said I want to do it right the 1st time. Thanks for all the input.
4spdragtop
4spdragtop
