RidingBean
Member
Hello,
I am having a bit of trouble that I could not find any existing messages about. I was hoping someone had already dealt with this and could point me down the easy path. As opposed to tracing wires all over the place.
Here is the issue: my drivers side front blinker works perfectly normal, at all times. The only problem is, when the parking/head lights are on you can't see it blink. The park filament does not disengage when the blinker is on, so it overpowers the turn signal. The passenger side is fine. I even switch out the lamp assemblies to the connector to check that and the driver side functioned the same.
Does anyone know where the signal to depower the parking light when the turn signal is engaged comes from?
Thanks
Thanks
