[SOLD] Parting Out 75 Duster
Moparparts
PA
Parting out 75 Duster 6 cylinder auto with front disc brakes, 7 1/4 rear with 10 inch drums, A/C, PS, black seatbelts. Post or PM with questions or requests.
Rear interior sail panels, upper front door panels, wipers, inside hood release assembly, tinted side glass and rear heated window are SOLD, windshield is still available
What would you want for the gauge bezel not the gauges just the plastic bezel?
I am selling the cluster and bezel together. I have a few other dashes and will check the bezels to see if i have a decent separate bezel and message you if i do
What do you have left?......looking for cowl, firewall area with good frame rails including dash frame. Cut the front off at the a pillars.....don't need sheetmetal, fenders, hood, or grille/ bumper
Yes i still have the front and rear structure but i need to get the K-Frame with steering box and suspension off yet to have a better look at the rails, i do know there is a small rust hole on the right side where the back K-Frame bolt goes in. The car had a windshield replaced years ago and was leaking so the dash structure was rusty and not usable except for cut out parts. I will update here or with a PM with pics and info when i get the K out
Im interested in the instrument cluster and the radio/htr control bezel. PM me with a price.
I could also use a second cluster bezel if you have another one in good shape.
just don't forget about me.....leave me a little something
Denny
Car is already taken down to just the rolling structure and has been for a while. I do have previous requests ongoing from a while ago for the disc brake set up as soon as weather permits to remove the K. The rear is still in rolling but the park brake system and rear drum and backing plates have been removed
disc brake set up, lower control arms, strut rods, PS box w/pump, Steering column, brake pedal, Front bench seat, rear seat, front bumper, front and rear bumper rubber fillers, front bumper to grille metal filler, wiring harnesses, fenders, doors, hood, grille, headlight bezels, A/C heater box, A/c dash vents, windshield and rear glass moldings and more are still available, post or PM for more info
how much for the front and rear bumper fillers? thanks
