Parts Needed: 72 Swinger
Are you converting to large or small bp brakes. I have large bolt pattern setup that has the upper control arms, lower control arms with sway bar tabs, backing plates, spindles, and caliper brackets. I have the same sb setup except the lowers do not have sway bar tabs. Also have a k-member, not spool mount. Southeast, MI area. Mark
I have an 8.25 rear end out of a 74 Duster complete drum to drum. Also located in southeast Michigan. Greg
PM'd demondevil
blu340dart I am talking to somebody right now with an 8.75 in kentucky, I'll Pm you if that doesnt work out
