PCV Port
Baffles made. No need to go buy some itty bitty screws to hold them in place
If you have adjustable rockers, make sure the adjusters don’t come up and smack your baffle.
Good looking out! I have stock rockers right now, how would I check if they hit the baffle? The metal is a super thin sheet metal I had lying around and I'm mounting it flush to the screw holes (not pre tapped for any particular screw type). I did the same thing that Johnny Mac did just not as pretty.
The stock rockers won’t ever hit that baffle. It’s the adjuster screws on adjustable rockers that could hit it. The baffle that comes with those usually just covers two rockers and the hole in the valve cover should be centered over that pair of rockers. Just something to check for when you do switch to adjustable rockers. BTDT.
Nice work.
I made a pair of baffles like that once (and loctited the screws in) for my MP cast covers. They work fine.
A couple weeks later, while looking for a different part, I found the baffles that had come with the covers :p Looked just about the same, too!
Adjustable rockers? Me? No way Jose, I dont want to take all of this apart again any time soon! Lol. :rofl:
Your baffles are perfect! Big enough to do the job and that's it. Better than the ones Mopar Performance sent with them.
Tried to screw in my baffles, small 12 x 1/2 in sheet metal screw and popped 2 of the tabs. What the actual ****!
I'm kind of lost at what to do now. The #10 screws were to small for the hole, the 12's seemed just right so idk what to do now. Epoxy weld it all or I dont have another idea as I dont weld or have a welder.
I used a self tapping screw but I can’t remember the size...may have been metric. If you can get two screws in there with LOCTITE I wouldn’t worry about it. One screw is iffy at best.
Gotta love working on cars...it’s always something.
These are sheet metal self tapping screws. I'm going to try and see if I can get 1 screw in maybe the next size down a size 10 and some loctite. Then if this epoxy super weld holds nicely I'll add screws in those holes too... if it does hold tight I may be able to lay a thin bead along a couple of the edges too.
This just sucks. And is just what the Dr ordered apparently :mad:
OReillys and autozone only had push on caps. I bought one but dont know it it will work as the grommet doesn't cover the full opening.
I took the gasket off my twist on cap put it on the bottom of the push on pcv filter cap then use grommet to hold everything in place on bottom side of valve cover. It's pretty tight but I think a twist on will be better to get.
They sell baffle kits for those valve covers. Just paid $9.95 for mine on Ebay, and these twist in breathers $42.00
Yes or JB weld! you do not want them dropping. Make sure it is Oil and Automotive compatible!
Idk if it is automotive oil compatible. Doesn't say on the box. I have JB weld as well. This is the current state with the epoxy weld.
It's a little hard to see but the screws didnt tap to far into the aluminum tab but was most likely from the pressure around the circumference of the tabs.
I used JB weld to fix the oil pan on Russian diesel tractor it's still in service 20 years later.
That JB clear is just regular epoxy probably good stuff but I know the regular grey JB works in oil.
Happy you said this. I actually went and got some jb steel reinforced weld, and rebuild the tabs essentially. I'll drill and tap the holes tomorrow and we will go from there I guess. I cant start the car until tomorrow anyways because I have to wait for the man to make it all happen. :thumbsup:
It may work great, but I'd always worry about that coming apart in there.
Me too!!! I really have no other ideas other than to drill out one of the other holes and mount on the other side leaving this side as the fuel filler only hole.
This is why I should stick to fixing teeth and not cars :rofl:
