Intense-Dakota
Active Member
Ok boys, now that I have the dart running, I am looking for some (mostly inexpensive) performance options.. Here is what I have have so far:
318 (not sure of castings yet)
318 Fast Burn heads
Offenhauser Single Plane intake
6-700 CFM carb, havent found the model yet (but I know it is a holley with vac secondaries and an elec choke)
MSD Coil
Accel 8.8mm Wires
727 Trans w/ TCI Shift kit
B&M Ratchet pro shifter
DynoMax headers w/ 2.5inch true dual (no cross over pipe)
Mopar Performance Valve covers and air cleaner (going on this weekend)
8 3/4 Rear w/ heavy duty carrier (not sure about gearing, hopefully find out this weekend when I get her up on the stands)
OK, I think that is about everything I know for sure. Here is what I am looking at in the near future:
Eventually replacing the 318 w/ a 340 (Or a thick wall 318 w/ 4inch bore and crank)
Replacing the transmission w/ a full TCI trans
4.56 gears
But for now, I am looking at what I can add to the 318 that can carry over to the 340, but will give a good performance increase as it sits. I am currently working on the following
Electric fan
Flamming river Manual Stearing Box
Mopar Orange ECU
MSD 6AL w/ remote timing resard (timing retard, just to scare the local when I pull in to the shows)
High Stall Converter (when the trans is replaced)
I am trying to NOT crack open the engine if possible, only becuase I dont want to put a lot of money into this engine, unless, it is feasibly possible to get into 12's with it....without spending the amount of money needed for the 340Becuase I have a "complete 318 w/ truck pan and pickup" I just built sitting here that was going into my 85 ramcharger, but will now be being sold to fund the dart...(hint hint)
318 Fast Burn heads
MSD Coil
Accel 8.8mm Wires
4.56 gears
Electric fan
Mopar Orange ECU
