Photos of factory AC compressor and serpentine belt system.
rustytoolss
Clinton, Ohio
any of you guys that have used the factory AC compressor/with serpentine belt system. How hard was it to reuse the factory AC compressor/brackets/serpentine belt system/ ac/heater box ? could use some pictures if you have any.
This is for future project planning.
Are you asking about the Magnum set-up or the aftermarket serpentine belt kits?
What car?
What year?
What engine?
What serpantine belt system?
What year factory AC system?
Otherwise I found it easy to adapt a stock 80s serpantine ford system to a 351 Windsor.
Are you trying to use a 95 Dakota engine, AC system and underdash AC in an A Body?
actual future build 62 Fury wagon. But yes 95 Dakota 5.2 is were I will get the driveline and AC parts
I would be surprised if the under dash parts would fit well, but you never know.
Im running a 5.9 Ram truck engine with the stock serpentine belt setup, except I deleted the AC compressor for now. But my plan is to use the stock magnum compressor, and buy the vintage air setup minus the compressor.
Don't see any reason that wont work.
Only thing I can think of is where the 95 AC compressor sits do you have hood clearance issues?
so you will be able to connect the stock mopar compressor to the vintage air underdash parts? Will you use the stock mopar condenser ?
I'm running the stock 5.9 Magnum serpentine set-up, the Vintage Air Gen IV evaporator and an aftermarket triple-pass condenser for R134 on the Magnum I installed in my '68 convertible.
The servo style Gen IV fits perfectly under my dash and blows very cold. I did have the factory A/C line manifold that bolts to the top of the compressor shortened a bit.
Here are some pictures...
Thanks thats just what I wanted to know. Like your air cleaner setup also.
