Pics on 340 air cleaner with flapper
Pompis
Sweden
Hi, I would be very thankful if someone with a 340 air cleaner with a flapper door could snap some close up picture of the whole mechanism on both sides.
Thank you FABO
The only handy one I have. What would you like to see?
I would like to see how the flappers hinge is mounted to the cleaner and the vacuum actuator from the other side. Thank you :)
A wire coat hanger can be used to replace the stock metal pin on the hinge.
I hope these pictures satisfy.
If not, let know.
