pictures (finally!!!)
ThogtheCaveman
Grand Admiral
orange county, CA
OK here are a bunch of pics of my project '69 dart!!!
o yea, a question for all of you. In the second picture (the closeup of the hood), i have never seen another '69 dart with the word 'dodge' in that kind of lettering, i don't even think ive seen one that had dodge on the drivers side like that. Does anyone else have one like this?? Maybe the hood is off another year? Also i found it funny that nowhere on the car does the word "dart" appear, inside or out, the only tag is on the hood, the dodge. I think maybe it was in a minor collision and the dart tags were damaged and the holes filled with bondo?
i have a 383 and 4 speed that i would like to put in it, but i do believe putting a 360 would be easier then a big block, plus i believe the 4 speed is a b body 4 speed so i think that will cause problems. Right now i am getting ready to rebuild the front suspension and coat floor panels plus k-frame with por-15.
great car. looks like a straight body, hows the pass side? the hubcaps and the fender mounted turn signals are a score. hood for a 67? look on line for emblems and they will say where they go. is it a swinger, 270, gt?
I would have taken pictures of the passenger side, but as you can see im too lazy to trim the hedge so you can't see it, but is bout the same as driver side. The only real problem is on the driver side at the very end were the body meets the covering for the tail lights there is some bondo that is falling out, i don't think you can see it in the pictures though. It is just a plain jane dart, i believe custom?? It is the very bottom of the line, i should probably check the vin one more time to be sure though. I do believe the hubcaps are plymouth and not dodge :)
As I see it that car has lots of potential. Heck it's already pullin the front tire off the ground!!! :)
