dartfreak75
Restore it, Dont part it!
I'm just curious I have no intention of changing my plans hahaoh geez.
However I would like to learn more about it for future reference
I didnt take any it was a section about an inch long and just enough to catch a nail on right at the the top where the ring ridge always is. It came out on all but 2 cylinders. He said it would probably be fine to run but I didnt want to chance it
He tried that. He thought that honing would take care of it and honestly it probably would run fine the way it is but he said he didnt really like it. He told me he has seen worse run just fine and he thought it would be ok but he didnt like it. And he wanted me to make the decision on sending it like that @40 or going 60 so I made the call to to 60. He said the walls had plenty of material to go 60 and he didnt think it would give me any trouble down the road at 60. I even brought up trying to find another block and he said that one would be fine. He said worse case we can sleeve those 2 cylindersDon't you have to final hone those cylinder walls yet after boring to fit each piston to each bore ? That in itself may be enough to reduce your area of concern at the top ridge area.
I would take a .040 piston ring and slide it up and down in the bore by hand near the top of the stroke. Doubt it will be anywhere near catching on the low spot that did not clean up.
Those piston rings are round and they will ride over whatever low spot is left behind.
You may have to go back to the .040 piston plan yet if you can't find the .060 pistons.
A little extra hone on those 2 cylinders at the top to help clean them up, the new rings will expand out and and take care of the situation.
Steal from Peter to Pay Off Paul . . .
Then you are not cutting another .020 out of your bores to get to .060 and run the risk of getting into the water jacket.
Ok well first off he didnt recommend low compression pistons. He just said he dont like kb and he would rather run a factory replacement piston than a kb. It's not like that.Because
#1 he recommended low compression.
#2 because he is willing to go .060, and did I miss that he sonic-checked it? LAs are "lightweight A engines" for a reason, not all will successfully take .060..
#3 Machine work already done to the block?
the "bore-ability" should have been the first thing to be checked, and no machine work started until it was known that whatever size decided on, would work. Now, you are stuck between a rock and a hard place. I mean I really hope it works out for you, But from where I'm standing right now, I would be very uncomfortable.
#4
I'm doing some research on it. If I'm doing my math right i can obtain a .040 quench with the kb107 pistons and a .028 gasket. With the gaskets I got It will be around .062 which is over I know.you got it freeking backwards
a race motor can avoid detonation because:
It's always running above peak torque
above BMEP
and it's always running good gas
now with tight quench
you are not as fuel sensitive
not as timing sensitive
not as compression sensitive
not as load sensitive
not having to shift down as much to keep from pinging
and 20 hp is huge
but the big gain is in low end and midrangewhere you can run more pressure wthot detonation
if you are going to run ft with the SMOG heads milled
run a thick gasket but they do not make one thick enough
run abig cam to blead off your torque
run low gears and a loose converter so you don''t load the engine
The more you lower your compression with ft the hotter it runs
you have to give it more gas to get the same power
the factory was chasing it's tail
go back to 67 not 73 and later
Use what they learned when the did the magnum - two quench pads
We did a LOT of dyno time developing that pston design with customm forged pstons- they work
I'd use ductile top rings either way
btw AJ can give you the details
Mainly the cost. I dont want to spend much more than 300 I will look into those you named and check them out. It's funny you said that because the machinist recommended me look into forged pistons and we looked up icons holy crap they was almost 700 a set I just cant afford that. But I will do some research on it while I'm looking.Why don't you just go forged with a Icon or JE/SRP or Wiseco/Pro-Tru? Why stick with a Hyper-U and fret over piston integrity and ring gap? Those manufacturers I just listed are quality pistons at affordable prices. I wouldn't hesitate to use the 107's gapped at .026" just like they recommend either--but if youre going to wring your hands about piston quality then just move to a real GOOD forged piston and be done with it. J.Rob
I see what you are getting at it makes sense to me now. Ok so I been doing alot of research and I have a question. I gotta go look at me heads and see how much area there is there on the quench pad on the chamber but I'm pretty sure after he miiled them they are pretty much flat but I got to check. I was looking at the kb190 pistons they have a .050 dome with the same ch. So the piston will be .012 under still but the dome will be .038 above the deck with the thick gasket that will give me .012 plus how much (if any) is in the head obvious if the pad is even with the head surface what wont work but it it's anywhere around .025 that would work out perfectly. And give me a cr of 10.8 so here is my question. I'm now creeping up into the mid to high 10s can I still run pump gas in the high 10s or low 11 range?I think you have the wrong idea about Quench. Every engine benefits from a tight-Q design..... especially a street engine.
Your engine will be; not might be, will be; more fuel-efficient, more responsive, happier, and be able to run at a higher pressure or on a lower octane fuel.
If you take advantage of it, your engine should make more power at smaller throttle openings, with less ignition timing, and less propensity towards detonation, at what some would call hi-compression.
If you don't take advantage of it;
You will have to reduce your cylinder pressure, likely at least 5psi, and increase your Q to more than ~.080 to stay out of detonation at full timing.
At or near 800ft, a 10/1 Scr with iron heads is already iffy, it will take a pretty good sized cam to drop the pressure into the zone for best pump gas.....
But I'm sure your machinist would have mentioned all this, and you probably just forgot.... in which case, sorry I brought it up.
Look; I really am a nice guy, and I really wish you all the best success.
BTW
In my 367, I run the KB107s loose, with large top gaps, like RRR, and others say using the nitrous/towing spec. I had to take my engine apart to make it so, because it would lock-up on me every time I shut it off. I installed Plasma-moly file-fit rings, custom fit ,in as near to perfectly round bores as it gets, and the result was a freshly installed LD rate almost immeasurable. And I was able to increase my minimum coolant temp from 180 to 205. Lemmee tell ya, that engine pulls real nice. The only successful run of four tries, it went 93 and change, in the Eighth, at 3457 pounds, 930ft elevation,with 3.55s and BFG Drag-Radials. The sixty foot was over 2.4 seconds, so you know the track was crap... or my suspension was,lol, but she still did the deed in 7.92 seconds, spinning most of the way. And it did it all with a [email protected] cam, a manual trans, and Q=.034.
You know that Quench, more correctly called Squish, is the distance between the piston and the top of the chamber, at the furthest from the sparkplug... right?I'm doing some research on it. If I'm doing my math right i can obtain a .040 quench with the kb107 pistons and a .028 gasket. With the gaskets I got It will be around .062 which is over I know.
Compression ratio is not the enemy.I'm now creeping up into the mid to high 10s can I still run pump gas in the high 10s or low 11 range?
What you really can't afford is a do-over. And that is what we are here for; in an effort to help you do it right the first time.I just cant afford that.
(Kbs are .012 under the deck and a .028 gasket) that will put me at .040. So I'm in that quench range. Why is quench unobtainable with flat top pistons seems to me I would be there?
The old "Too Many Cooks Spoil the Stew" routine.
Nothing has changed with the build Its the same pistons same heads same cam. I'm not changing anything. I'm just trying to learn something new.See? This is what I meant when I said "geez". You should have just built your engine like you wanted originally. Now the waters are muddied up in the quest to get what? 20 more HP due to quench? God god almighty man.
Nothing has changed it with the build Its the same pistons
