Yes I managed to soak up the surface with a towel and used a trasnfer pump to get most of it out. I can still see a bit in there. Will this be enough not to cause any harm and will an oil change drain the remaining coolant?? Thank u for your feedbackU need to get it all out. Do u have a shop vac? Soak it up with rags or paper towels. It u have an air compressor u can blow the last little bit out. KimKim
Yes drained all coolant plus I had to remove the radiator. As soon as I roke the head free coolant started to pour out. The driver side head was dry no coolant. FYI I did not remove the drain plugs form the block, is there one on each side? and were is it typically located? TDid you drain all of the coolant before pulling the heads? It is not uncommon to get coolant in the cylinders when you remove the heads if you did not remove the drain plugs from the block. As long as no coolant gets into the crankcase, you should be fine. Of course you need to change the oil and filter before starting it up, and again after breaking in the cam. When draining it the first time, look for signs of coolant in the drain pan, the old saying "oil and water don't mix" is evident if there is coolant present. As Oldkimmer said, it is imperative that you get ALL of it out of the cylinder bores before reinstalling the heads, also wouldn't hurt to wipe down the cylinder walls with oil too.
Now that's smart thinking, I'll have to remember that when I do the engine for my 75I actually replace these pipe plugs with 1/4" NPT petcock fittings. The kind that are used on radiators.
Block drains are located just above the oil pan rail on the bottom of the block, typically will require a 3/8" square drive, some will be a square head plug, 7/16 or maybe 1/2 inch wrench fits them. They will likely very tight, one per side, good idea to still take them out to prevent further problems on reassembly.
