Thanatos340
Here we go.. I had a 76 Duster/Valiant I was trying to fix up but it was going to require new lower quarters, a new tail panel and other body work that I just was not comfortable doing. Major body panel replacement is beyond my skill set. I had already replaced the interior in it, had the seats recovered, new carpets, ect.. but the body was scaring me. The 76 has a 69 340 in it that has tremendous sentimental value to me as it was the last engine my built before he passed away. What to do...
I lucked out and found a 73 in fantastic condition but needed an interior and I was able to buy it as a roller.
This weekend we were finally able to get started. The floorpan had a good bit of rust but was not far gone. This weekend it was pull the interior, sand it down to metal from the trunk forward, Por 15 the floor pans, Epoxy prime and finish off the rear and trunk area.
Also since I am not a huge fan of the B3 Blue and chrome look it had, Try to change it up some by adding adding some black. Blacked out the bumpers and added a Black Stripe to the Hood.
Plans for next weekend:
Address the front end problems with the car. It has one bent strut rod and the other strut rod has a bad bushing. I will be replacing them with some Dillinger Adjustable Strut Rods and hopefully some adjustable UCA`s if I can scrape up enough change. Then adding Flat Black 340 Stripes and a Go wing.
Then it is just a matter of moving the Motor, trans and interior from the other car over.
This is not a full resto, Just trying to fix up the car the best I can with resources I have.
Here is round 1:
Here is round 1:
