Plastic Fuse Pullers-What a Joke
dibbons
La Paz, B.C.S., Mexico
I had to resort to a screwdriver. The two little grab arms on the yellow item just flex and bend and slip off the fuse. The hook on the black one pulled out one fuse successfully. On the second attempt half the hook snapped off and made it useless. Did not try grabbing them with the pincers, just gave up and brought out the screwdriver.
Thanks for reminding me...I hadn't heard this song in ages
I have no problem with the little plastic fuse pullers. THEY ARE ALL MISSING so I don't have them LOLOL
pulling a fuse out with those tools again? The Jokes on you!
I actually had luck with the mini fuse puller in a 03 silverado. Not so much as a 'pincher' but an opposing hook design.
I use the plastic pullers for the blade type fuses. They work if you grab them near the fuse, so they don't pop off. For the round glass fuses, I just bend a hook in a cotter pin.
