[WANTED] Please help: I Need 1966 Plymouth Barracuda master cylinder and pigtail electrical piece
'CudaChick
Active Member
Chico, CA
Rating - 0%
0   0   0
Please help: I Need 1966 Plymouth Barracuda master cylinder and pigtail electrical piece. My cuda master light is smoking, with flame and now is burnt.
Also looking for headlight floor dimmer bright switch. Please anyone!
Thank you
Chico ca
Hayley
Thank you
Chico ca
Hayley
if you're going to replace the MC, may as well upgrade to double-pot - gives you that little bit of an edge when you absolutely have to stop
Yes, it's good to upgrade to the 67 and later dual reservoir master cylinder so if you bust a brake line you still have half the brakes working vs none with the single reservoir master cylinder..
Advance Auto has the headlight switch
They also sell the dimmer switch (but you cant use the plastic case on it)
I found an oem dimmer on ebay (fits in the case)
Hayley, those headlight switch plugs seem to be a problem area with our older Cars. The problem is there is quite a bit of amperage drawn through them, especially if you install aftermarket headlamps. I'd suggest doing the Mad Electrical headlight relay mod after you install the new pigtail and switch from Whitepunk. It takes the load off the electrical system and lets the relays do the job. It also makes the headlights quite a bit brighter. It's not hard to do either.
Here's a link to it. They show doing it on a GM I think but the process is the same.
Catalog
