[FOR SALE] Plug and play - Headlight Relay Kits
Is there any benefit to this if you are running LED headlights? I know technically the relay is better, just not sure it is needed with the LEDs.
Anything you can do to relieve the OEM harness of load is a good thing.
LED headlights usually draw pretty decent amperage. The claimed levels of reduction aren't what many think.
Hey Crackedback im in the process of working on my 71 duster, got the dash apart for a refresh of paint, new dash pad etc… my head light switch was toast from rust replaced it with OEM switch. This is what I found which is the second abody i seen like this. See how the female connector green wire gets hot and melts the plastic. RatRod Al sent me a nice connector replacement.
Please make me up a kit and I’ll run it under the battery tray like the others have posted. I got new parts but before I put it all together and test it. I probably should add your kit to protect it from future damage.
Thanks send me your payment info..
Thanks send me your payment info.. View attachment 1716476333View attachment 1716476334View attachment 1716476335
The green wire is the wire headed to the dimmer switch powering the system after your switch. You have to replace the toasted terminals in that connector.
I'll send you a PM.
Car is looking good!
I purchased Crackedbacks relay kit and it’s as advertised a quality upgrade, it took very little time to deliver and I install it same day up under the battery tray, the relays and 30amp fuses are very accessible with how it’s mounted and not visible unless you know where to look. Rob sends detail instructions but like most dudes I just went for it and was able to get installed. Thanks
I am in the market for a two light harness for my 72 Demon if it fits your schedule. I am dealing with very dim lights right now. I have standard sealed beams and want to upgrade, but after reading this thread I want to upgrade the wiring with your setup 1st.
If you can accommodate please send me your payment info.
Thank you in advance.
Last Friday I received my headlight relay kit from Rob and got it installed over the weekend. This is a very high quality piece that was designed perfectly to route without unnecessary extra length. Very easy to install, and with my new Sylvania Silverstar headlights they are very bright. I live in a rural area with a lot of dark roads, so this will help a lot.
Highly recommended!
Hi Rob, I sent you a message, want to get your kit for my stock setup 1966 Plymouth Valiant with 273.
Got more materials coming in. Have a few kits to finish up and on the way.
Two Time Signet bought a relay kit and some battery cables for his early A They look OK... :)
Sold a kit to Dave in Hawaii and he sent me these pics of the interior lights. Ran up the RPM a little on the bright ones. same setting on headlight switch. So bright he needs to turn the setting on the headlight switch down a bit.
