[FOR SALE] Plug and play - Headlight Relay Kits
Headlight relay kits that are essentially plug and play.
There is a substantial increase in voltage at the headlight, increasing light output performance. Light output degrades exponentially with voltage input reductions. These kits also take headlight amp loads off the fragile bulkhead connector, headlight switch and amp gauge. The only headlight load flowing through the bulkhead is a minimal current required to trigger relays.
The kit includes:
Bosch/Tyco relays (no 1$ chinese relays)
Ceramic headlamp sockets
Fuses/fuse holders
12ga wire from alt to relays
12 or 14 gauge power wire from relays to headlight wiring (no 16-18 gauge wire like factory, except 16ga to trigger relays)
All terminals for hook up to a std 1/4 alt stud and ground locations
Wiring would follow normal wiring harness paths and be covered with black shrink tube for most of the run lengths.
NO CUTTING OF YOUR CURRENT WIRING HARNESS REQUIRED!
Road lamp relay kit is not included in the standard 2 and 4 headlight kits. There is an additional charge for a road lamp relay kit.
The kits I've built have relays mounted on the yoke (front or rear), under the battery tray and inner fender uprights.
Picture of the light output difference from a 71 Cuda. Both pictures are on low beam setting, Left - before, Right - after installation.
Another benefit that most users see are an improvement in dash light and marker light/turn signal brightness.
Some other things to consider.
Unless you buy wire in bulk, you'll have about $40+ before tax in different colored wire packages from a local auto store.
All kits I build are tested prior to shipping.
Kits for a 2 headlight vehicles are $135 + shipping.
Most 4 headlight vehicles are $160 + shipping.
The assembled kits fit nicely in a USPS flat rate box, shipping in the US would be in the $10-15 range. International shipping is available. Kits have been shipped to Canada, Spain, Italy, Germany, Australia, New Zealand and a few other countries. Most all shipping is done via US Postal Service unless other service is requested.
Kits with all products and wire required to build one yourself are $85 for a 2 headlight and $100 for a 4 headlight + shipping.
If you would like some other iteration of a kit, parts only, please PM me.
All items are shipped from Indio, CA
Thanks to all my customers, I appreciate your patronage!
The kit includes:
Fuses/fuse holders
Thanks Rob that's a quality product with quality service hope to do business with you again soon
Got my kit the other day and put it in last night. Haven't driven it at night yet, but it WAS dark when I finished up last night so I fired her up and turned on the lights at least to make sure everything was working ok. I installed new Sylvania Halogens when doing the install, and instantly noticed the increase in brightness, and appreciate not having to worry about overloading the old factory wiring.
Nice kit, easy to install!! The only thing I will say is when Rob says the new connectors will be a tight fit getting them into place behind the headlight boxes, and to be careful with the new ceramic connectors,..... He means it. I got mine in place safely, but only by sliding the rubber boots up the wire and manipulating the wires a bit. Glad he pre-warned me to be careful with them. This issue isn't on Rob,... it is on the designers for Chrysler. Don't know why they left such a small channel to get up in there?!?
Don't think about it,.... just buy it! You will be happy with the results!
Hi Rob,
any chance of getting a 2 headlight kit sent to Nairne 5252 South Australia. If you can let me know the cost & type of payment preferred, it'd be much appreciated.
Been struggling with voltage on the car for a while using cheap asian relays, this kit sounds likes the ducks guts.
Received my kit today and I am impressed with the quality of the kit and very detailed instructions. Looking forward to better headlights. I really like the design of the harness.......The way it works is simple and effective...without a rewire of the stock harness..Thanks again for sharing your knowledge with all the folks at FABO. Steve
Got my kit yesterday. Top notch work, quality materials, and clear, detailed instructions. LOVE that it's "plug and play" as I'm not a wiring/electrical expert.
Next will be a convertible top relay kit!
Thanks for offering these, Rob!
vm
Good afternoon Rob,
Received your package! Looks awesome and very professional, 1000x better than the stock wiring that is for sure.
Although I will not be installing for a while yet, I have reviewed your installation instructions and am very confident install will be a breeze!
Thank you very much
Troy
Rob,
Thanks again for the kit and for taking the time to talk it over with me on the phone. Awesome looking piece and can’t wait to install it!
Thanks for the positive comments. Any questions during install, don't hesitate to shoot me a message.
I have received my harness kit weeks (maybe months ago) but the car was at the body shop. Looking to install within the next few weeks. I do have one question: if I decide to do a trunk-mounted battery will it affect how I install this kit?
Thanks ohhh and the kit is Top-Notch!!!!
Can't wait to be able to actually see at night without having to have my Hi-Beams on.
Prican,
It should not be an issue. I don't recall where I set up your kit to pull power. If off the alternator, it will be fine.
Rob
got my kit installed last weekend... quality... quality... quality..easy install with basic knowledge.instructions are easy to understand.truly plug and play.. as advertised. a highly recommended vendor... and upgrade... thanks rob.
Good to read you are happy with the kit. I try my best to make a great product.
Think I answered all PM's and emails.
If anyone is interested in a kit, please let me know.
Thanks
Rob
