guys bought a plug and play and can't get it to work,, 4 guys looked at it and no luck,,changed coils and no luck,,2 say i'm missing a piece,, the car has push button start, close to putting duel point back if i can't get to work,,,,,,,,
plug and play distributor,,,
Red to coil (+), Black wire goes to coil (-), bypass balast resistor. Re-clock rotor to #1, because drive lug is off by 90 degrees from OEM.
here's directions and pic's ,,, hope this will help,, yellow wire is grounded to firewall from neg side of coil
thanks for help,, i don't know a thing about this DIST or hook up,, i relied on others to hook it up as i am members on this site for help,,, i can see that was a bad idea [67dart] my mistake,, thanks for all who did try to help
