Pluging Fuel Line while working on motor
340inabbody
Arizona
Guys I have silicone rubber plugs will that be ok to plug my fuel line in my bay for a few months? Not sure if that material will breakdown fast. Don’t want a floor full of fuel one day.
If not what do you guys do/use?
Thanks,
Ron
i have a few bolts with the threads turned down that jam into the hose snug up with hose clamps.
if you have a fitting on it you can just use a plug.
realistically, you shouldn't have any more fuel than what's in your carb and pump/lines from the rail up. so not a tremendous amount to sop up proactively.
Main supply as I am removing my carb.
Rubber only for anything petroleum base. Silicone will get soft and swell. if you do use them secure them with a zip tie. silicone is usually used for powder coating and painting. so the material does not stick.
