kent spaulding
spauldo
:sign3:I'm plumbing my fuel system and would like some advice from you all on what works and what I should avoid doing? I have a 340>410 stroker motor that has 478 hp @ the crank and I am running a 770 cfm Holley street avenger dual feed carb. I also have a new Aeromotive 17247 fuel pump with a Aeromotive 13201 regulator and a sumped stock tank that has a couple of half inch NPT female couplings mounted into sump (low point back of vehicle).
I was told to run a -10 AN feed with a -8 AN bypass and a -6 AN to the carb. I have always thought that you should put the regulator before the carb but have read differently on this site. I am running just plain old rot gut fuel in this car not E85. Any suggestions or visuals you could give me on how to get this done would be greatly appreciated.
