plymouth duster quarter skins?
tfinley
st louis mo
I am starting a restoration on a 72 Plymouth duster. My question is about quarter panel skins. has any one used a AMD skin? They don't just make the skin any more and the full panels are on back order till the middle of the year, at the soonest. I have found a set of AMD skins. Does anyone know if the skins have the door jam edges, window seal area along with mounting to the truck drip edge ? or is it just the skin that is flat no 90 degree edges? Any help is appreciated.
So I purchased AMD dart swinger skins in the closeout sale and they have the door jamb edge. They're not duster but would imagine they are the same general design
Just checked mine. It does have the 90° flange at the door jamb. It does not go as high as the quarter window. It doesn't reach the trunk drip rail either. I believe it only approaches the uppermost ridge on the side that extends back from just above the door handle.
I had 71 duster skins from them and they stopped at the body line just short of the trunk. So no it wont have the wshield trunk spot weld area
