Plymouth duster quarter windows 70-73?
bradford
Professional at nothing
N.C
I’m trying to figure out if a 70 Plymouth duster pop out quarter window will work in a 73 duster? Does anyone know if they will work? Thanks
Im pretty sure it will the only thing is you better make sure you have the correct interior sail panel so it doesn't interfere with the hinge
Okay thanks. My sail panels are from the same car, a 70 duster. So I hope they will work.
I believe 70-72 Dusters used a chrome handle and 73+ used a plastic handle.
If I remember right, the frame and glass will fit just fine but the hole is drilled in the glass in a different spot so you'll be forced to use the chrome handle.
