Apr 22, 2021 #1 bradford Professional at nothing Joined Feb 3, 2011 Messages 67 Reaction score 40 Location N.C I’m trying to figure out if a 70 Plymouth duster pop out quarter window will work in a 73 duster? Does anyone know if they will work? Thanks
Apr 22, 2021 #2 lenky1 Well-Known Member Joined Jul 30, 2014 Messages 974 Reaction score 779 Location illinois Im pretty sure it will the only thing is you better make sure you have the correct interior sail panel so it doesn't interfere with the hinge
Apr 22, 2021 #3 bradford Professional at nothing Joined Feb 3, 2011 Messages 67 Reaction score 40 Location N.C lenky1 said: Im pretty sure it will the only thing is you better make sure you have the correct interior sail panel so it doesn't interfere with the hinge Click to expand... Okay thanks. My sail panels are from the same car, a 70 duster. So I hope they will work.
Apr 23, 2021 #4 E ESP47 Well-Known Member Joined Jul 3, 2009 Messages 2,818 Reaction score 1,928 Location Sacramento, CA I believe 70-72 Dusters used a chrome handle and 73+ used a plastic handle. If I remember right, the frame and glass will fit just fine but the hole is drilled in the glass in a different spot so you'll be forced to use the chrome handle.
Apr 23, 2021 #5 barbee6043 barbee 6043 FABO Gold Member Joined Jul 20, 2008 Messages 23,737 Reaction score 15,379 Location Shepherd, Texas ( SE Tx) Anyone need a 71 Righ tside Duster pop out quarter window?
