mopowers
What is this large contraption attached to the vacuum advance pot on this old points distributor? The distributor is off a 400 FWIW. Thank you.
Lmao.
Rusty, I didnt know you liked... "Mr. Heat Miser...Mr. 101°"
Seriously, Show that pic of the distributor to @halifaxhops, he may know a bit about it.Thanks guys. I've never seen a vac advance relay like this before. I'm assuming I can just ditch it and replace it with a normal vacuum advance pot with no ill effects? I was thinking of using this distributor to get my 400 running. I'd just need a ballast resistor and coil.
Alternatively, I've got a MP electronic distributor and extra HEI module I may wire up instead. I just need a coil for that one.
"..Whatever I touch, melts in my clutch.....I'm too much!" I loved those holiday shows.
Oh so you know when looking for a normal vac advance you need one with a straight arm. Think the one you have is a 9L.
Correct. Both my 71 Charger R/T and GTX had that.Thats one of Mopar's finest right there. Used on the HP 383, some 400 and 440 mostly RR and Chargers. Works like a regular vac advance but has a solenoid for 5 degree retard when shutting down to avoild dieseling. Think about it the ignition is off. Dump it and get a regular vac advance unless your doing a high end 100 point restoration. Not cheap to replace 150-450 depending which one it is.
Different years usually but not only. Dont ask me if there is a rhyme or reason with them, I have seen either on the same number distributor. The straight arm is hard to find. I get mine rebuilt since they are so hard to fine. And a 50 year old diaphragm is bound to break.Thank you for all of the info. What's the difference between those vacuum advance pots? Is one for points and one for electronic ignition??
