805moparkid
Slant and AFX Guy
is there such a thing? rubber does not hold up well here in AZ
You know, I just thought of something. It's a bushing. Get some aluminum stock and buy some Moog offset bushings. Turn you some down in aluminum in a lathe. Drill a hole and tap them for grease fittings. Done deal Lucille. How hard can it be?
That will make them into plain bearings/solid bushings...
But that will bind when the A-arm is moved up and down after you adjust the front and rear cam eccentrics in/out and up/down. If the inside holes are kept on the same axis, there will not be any binding. But that will only happen if the front and rear cam eccentrics are rotated exactly the same. And that will only allow caster adjustment.
Therefore you can't put an imaginary straight rod through the front and rear upper control arm bushings in a Mopar after you adjust them. The front and rear bushings will be on a slightly different axis. With offset bushing there is an even greater difference of axis.
THAT is exactly why I used rubber in the top, but not offsets.
I got enough caster with the factory rubber.
im going with big bars, bilstiens, 255/50-16's so i want it to track really well, also help get some feel in the steering... after i get the suspension dialed i will adjust the PS pressure
I'm more after the daily drivability and reliability.
Not saying yours would be less so, just that it would be overkill for my car I think.
I may very well "pump it down" on the power steering though, and have been considering it for awhile now but I have other priorities with it right now.
Nothing is wrong really, just details.
