POR15, undercoat, or sprayon bedliner?
i understand the dt for the flow has your rep ever recommended adding a super charger?
Years ago I knew about super charger...I didnt know they still made it. I use to use DX101 to speed up some of the clearcoats. Speeding up products to dry fast has its disadvantages normally it will make products more brittle/yellow or they will stone chip like a SOB.
your right about that. but i have found an eye drop or two can help with production times it's something you need to perfect your self. i can't afford to mess up that ground coat either
Cool, thanks for taking the time to write this. Sounds like I'll be on the right track now. Thanks for all the advice. :thumbup:
not a problem i'm passionate about what i do and i have to do it right. like i said the process is lengthy but the outcome will be rewarding.i'm just over the border south of lake geneva so if you need a hand you know where i am
Great information in this thread. I wish paint and bodywork was a skill I possessed.
I miss spoke DX101 is a scuff creme, I meant to say DX84 Enhancer.
