Positive Grounding Vehicles
Yes too much for my 50
And don't care ...like it vintage
Remember people doing the conversation on old vw without a lot of parts
But they are neg ground
yes i know; i was saying i personally havent worked on any mopar positive ground systems.
55 and older had it. I never worked on those systems either, but I did the conversion on my 52. I couldn`t get any electric gauges working even with 6V reducers, any way they were hooked up. Did get the wiper motor working with voltage reducer, that`s it.
well i hear starters spin like hell with 12 volts hooked up:lol:
My 6V horns work with 12 but it blows the fuse if I lay into it. I probably need heavier wire and a relay in the mix.
heater motor speed resistance coils work well to drop the voltage on those
ballast resistors work well on low current light systems too
use a mid/med speed coil for high current stuff.
and many instruments don't realize +/- swap other than the ammeter
convert the generator/regulator, good to go
a convert can be cheaper than a high current 6v battery vs 12v
1956 was the first year Mopars used 12 volt negative ground. (At least for USA and for cars.)
My 49 Wayfarer had six volt positive ground. I converted to 12 volt so it could run the same battery as the rest of my cars. And also because most six volt over-the-counter batteries you get at your local parts store suck.
My wipers are vacuum, I don't have a heater or working radio, I used something I forget the name of on the headlight switch, replaced all the lights and bulbs with 12 volt, switched ammeter wires, 12 volt GM one wire alternator, and a lightweight 12 volt starter from Hot Heads for a Dodge hemi V8 (had to re-clock it), Pertronix electronic ignition and 12v coil. I think that's all.
The six volt starter worked with 12 volts, spun real fast, but if you had to crank it for more than a few seconds, it crapped out.
Early Fords and Chevies also ran 6 volt positive ground until the mid-50s. I think they went to 12 volt negative ground in 55, but don't quote me on that.
49 Ford pickup I owned just long enough to get it running and sell. Six volt positive ground.
