snowmobiler7c
I am rebuilding the whole front end on my 70 swinger and swaping to the kelsey hayes style disc brakes at the same time. When i first got the parts i sandblasted and painted everything with POR15. I am now reassembling the parts. When i got the uppers the ball joints were already removed. I thought they were threaded in but started to screw in the new ball joint and only got it hand started a small amount, then just a little more with a pipe wrench. So i decided to grab the manual i have laying around. It says to reinstall the upper ball joints to press them in. Thats what i did with the first upper control arm. I then stoped at the second arm and got online to find out the damn book must have a misprint. So now i have one control arm with a brand new pressed in ball joint. Should it be ok??? The joint is in there super tight i cant see having it pop out. I tried the pipe wrench and cant get it to turn either direction no matter how hard i turn the wrench. Im thinking it should probley be fine but the arm will be junk if it ever needs to be replaced in the future, just looking for some opinions before i throw it all back together
By the way i was able to get the second ball joint in properly in the threads.
thanks for any input
Mark
Mark
