[WANTED] Powe steering pump pulley 69 and earlier
plumkrazee70
Medford, Oregon
I'm in need of a power steering pump pulley from a 69 and earlier. It is the key way style pulley. Unfortunately, mine is bent. It's the last in piece of the pulley puzzle I've been fighting.
Thanks!
Michael
Sometimes you can straighten out those pulleys. I've done quite a few in the past. A hydraulic press helps, but, sometimes a vice is enough.
Bingo!! Do you still need the power steering pulley??
Yes, cuz mine's bent. I think using a gear puller to pull it off jacked it up. I can press it back on by hand, but when I spin it, it is definitely wobbly.
