Power Brakes? Is it possible?!
75Dart440
Active Member
Inver Grove Hts Minnesota
Has anyone ever seen an A body with a 440 that has power brakes? Got any pictures? How the hell is it done. Ive got one that has power brakes.. But cant get the power to the brakes... 14 hg vacuum. 8" booster. Pedal is Rock hard.
early gm cars used an electric vacumn pump on the 4 cyl models maybe ajunkyard and alittle wiring good luck
That should be enough vacuum. You may have a bad booster. I went through that with my old 67 fastback. I finally went to manual brakes.
