^^^ not you, but to say instantly 5 grand on just motor, and 10 grand to do it right, who can play in our hobby????? Also, I agree the EQ heads are a plus in performance, and they may not crack, and if in the budget a it's money well spent, BUT............. the factory magnum heads are the best small block mopar heads made from the factory, so they will perform. And as far as the cracks, well, it don't seem to bother the running of the car at all. In fact, to know if they are cracked, you got to take them off. Are my heads cracked on my 5.2 Durango at 202,***?? Or on my 5.9 at 229,***???? Most likely, but no one know because it runs fine, doesn't overheat, ..... get what i'm sayin?
P.S. - to the OP, I watched a 92 Dakota 2wd 5.2 with factory 3.90 gears automatic turn 14.60's off of a computer upgrade. No mods to the intake, no EQ heads, no cam change, no headers, no injector change.
