Power steering pump EMERGENCY Los Angeles
While I’m here might as well point out that my rear end just about dripped itself dry the past week. I’m assuming it’s just a gasket? Or seal whatever u want to call it sorry for my adolescent stupidity and thank u guys for helping me out
Haha that’s what I’ve been doing but I feel like it’s not too good on the box so I just left it out in my driveway ready for a new pump. For people saying I should rebuild I overtorqued the pressure hose and broke the threads on the pump ( Please call me an idiot) I know rookie move right.
That fitting unscrews from the pump. Be ready for it, it has a spring and maybe some washer behind it. That's the pressure regulator. You can put in the wanted section a picture of it and I am sure somebody has one. You don't need the whole pump.
Bravo !! Rusty......Exactly the advice I was going to give as well..Did the same thing when I was about his age ,had a shaft seal so bad it came out almost as fast as you could poor it in !!..Took a couple days to get one.Big arms at the end of the week though ..swingn’
Don't know. We're not there to see it. You have the rear end cover gasket, an axle seal on each side and an seal right behind where the drive shaft yoke on the pinion gear. Inspect each of those areas and you will find where the leak is.
Crystal ball broken Rusty?
So here’s my pump you can see where I broke the threads of you have another one of these Roy SGbarracuda ill gladly purchase off of you thanks guys for the help I would’ve been **** out of luck
Ouch, yeah you will need a whole nuther pump. How in the heck did you do that?
Post a pic of the pump you are looking for. As you now know Rusty is one that when hes on your side is great! When you pi$$ him off, you will know about it lol.
Yer young so LOTS of learning left in life.
**edit** got pics loaded before I finished typing.
Thanks guys I’ve been called “hot headed” a hell of a lot before, not a good trait to have in this type of predicament
Stupid Chinese pressure hose and my pissed off strength trying to get that thing on during night time, one last turn and bam there goes my pump
I almost blew up my engine because I worked on it at night, don't so that anymore, unless I'm in a brightly lit up shop.
i'm not home, and won't be able to check what pumps i have until tuesday, but if you want to drive up to van nuys any day after monday you can have one of mine.
anyone know if either pump will fit on his brackets?
According to your picture here, that's not a Federal pump. That's a TRW pump. Look at the picture of the two pumps on the first page. Yours matches the TRW.
If I was 17 I'd go back to that junkyard and get a manual steering box. Now if you consider that, you'll have to disassemble part of the steering and buy a steering shaft adapter.
Im down in Long Beach and so i can come up to van nuys if you’re willing to sell me one, thanks really appreciate it
