Power Steering
TAQuickness
Houston
My 65 Dart will leak the entire reservoir in ~5 miles of straight road.
From searching the site, it seems replacement pumps were plentiful 1-2 years ago, but I can't find anything now.
Are there compatible pumps from a later year?
If not, how are y'all maintaining your pumps?
I browsed thru, they don't sell pumps, rather a rebuild service. Hard to navigate on an iPhone too.
This looks to be pump from a 65 273 bolted to my 318 (neither are original to the car).
Where is the leak? If it's the shaft seal, the last one I bought was through NAPA. If it's the "O" ring between pump and reservoir, they can be found many places. If you have a chronic leaker, run a thin coat of rtv on the "O" ring and corresponding surface of the reservoir after you've cleaned them up real good.
Going to give a DIY rebuild a shot.
Does anyone know where you can get a replacement resevior cap? The previous owner was using a freeze plug.
I may have one.......post a photo of your pump so I can see which one you have.
Thanks, Mark
Well, that narrows it down to two.....does yours have 2 inside notches like a fuel filler neck or a couple outside bumps? I can't be sure from the photo.
If hemi71x doesn't chime in, send him a PM. He is real sharp with stuff like this.
Here's the one I have. Fits the reservoir with the internal notches.
