power strg columm
72wildone
Member
porterville,ca
Rating - 0%
0   0   0
have a friend just bought 72 duster ,wants to change over to power steering, looking for strg columm and/or all parts to do switch call mike at 559-310-7136, central ca.:read2:
I should have a complete column shift automatic setup. Need to know which engine you have for the pump, pulley, and bracket parts and if the car has factory A/C. They run $175-200 plus the UPS ride.
Thanks, Mark
I have a complete power steering set-up from a small block. Includes Pump, box, pitman arm, center drag link and tie rod ends in very good condition. I'm in Los Angeles, $320 for every thing.
If his manual steering set up (box, column, etc) is in good condition, I would consider trading my P/S setup.
