Pre C-Clip 7.25 Seals?
blind bat
New Hampshire
My 65 Dart has a 7 1/4“ rear end that uses bolt-in axles. I started out replacing the sloppy spider gears and things escalated. I figured while everything was torn apart I ‘might as well’ replace the axle seals and the axle flange gaskets.
I can’t find a part number for the axle seals that live in down in the axle tubes (like a 8.75”). Rock Auto has two options (MAHLE P33114 and VICTOR REINZ 711450700) for flange gaskets but both are out of stock. Anyone know where to find axle seals and flange gaskets?
Here’s some pics of the old girl:
BTW, Who at Chrysler thought it was a good idea to require the ring gear to be removed in order to remove the spider gear shaft?
Axle seal part number: 2404052
Flange seal part number: 2467095
Both can be found on eBay.
