From summer 2010 until now:
SUSPENSION
TORSION BARS: 1.14" 320 Lb./ft wheel rate stock .87" 109 Lb./ft, livable, pretty stiff, Hotchkis shocks were key to taming them.
REAR SPRINGS: Hotchkis. Weigh less that stock.
FRONT SWAY BAR: Hotchkis 1 1/4" hollow
REAR SWAY BAR: Hotchkis adjustable ¾" dia. hollow
SHOCKS: Hotchkis Bilstiens
STRUT RODS: Hotchkis tubular with heim ends. Precision articulation. Can set for nice bind-free LCA up and down movement. Holds poly LCA bushing against K-frame
A-ARMS: Hotckis Tubular. Able to dial in any caster desired.
SUBFRAME CONNECTORS: Hotchkis
73-76 K-member: reinforced
STEERING STEERING GEAR: Replacement Mopar remanufactured. Large steering gear spline, crisp, firmer, but not Firm Feel
PITMAN, IDLER, CENTERLINK: all 73-76 A-body, to accept large spline gear, Moog parts
POWER STEERING PUMP: Saginaw with rear oriface drilled out 1/64 larger. The other Mopar pump will not keep up with rapid steering input and are generally poor.
POWER STEERING FLUID: Justice Brothers heavy duty, don't change often, so extra cost is cheap assurance
POWER STEERING CAP: later style multi knobbed style with rubber baffle to stop spitting up.
BRAKES
PADS: Discontinued Mopar Police Spec Semi Metalic units ($15 swap meet score)
DISKS: 11.75" dia junkyard single piston disks
BRAKE LINES: braided, w/banjo on caliper end for rear caliper placement
BRAKE FLUID: Justice Brothers High Performance Dot 4
MASTER CYLINDER: Mopar Performance alum. 2 bolt, 1-1/32" bore, firm immediate pedal, feels great, not for your grandma. Started with manual drums. Thicker master cly adapter to adj. pedal height down. Be aware of pushrod length.
PROPORTIONING VALVE: Willwood adjustable, had drum brakes so need some proportioning valve
DRUMS: vented "bell or hat" drums for cooling
REAR AXLES: 4 ½" bolt redrilled pattern
WHEELS
15x9 4 1/4" backspace Optima Minilites (needed front fender lipping/bending) 245/50/15 BFG Comp T/A's ZR all around. (That size is totally discontinued)
INTERIOR
STEERING WHEEL: LaCarra 15" padded leather, better grip, small dia. gives more responsive feel ($30 never installed swap meet score)
SEATS: Used Toyota Celica GTS increased gs so need better seats, must race car from drivers side
From 1994 to summer 2010 **OLD SETUP**:
SUSPENSION
TORSION BARS: .99" 184 Lb./ft wheel rate stock .87" 109 Lb./ft, livable, stiff
REAR SPRINGS: Stock for 8¾ 68 Formula S. Car seems balanced now. Might need stiffer so don't need rear sway bar. If so, will just add leaves to dial in. But soft helps planting and rear transfer. Good shocks might have to come first. Need testing to sort out.
FRONT SWAY BAR: Hellwig 1 1/4" hollow
REAR SWAY BAR: ¾" dia. Addco aftermarket ($35 used)
SHOCKS: Front QA1 single adj ($75 used) blew out all my hand-me-down used Konis, Rears: Hand me down KYB's
POLYGRAPHITE: sway bar, brake strut rods, lower control arms. Leaf bushings; can hear slight resonance when added to rear. Would not use LCA poly again.
UPPER A-ARM BUSHINGS: offset, Moog prt.# 7103 installed opposite, more caster, more road feel, more high speed stability
BRAKES
WHEELS
INTERIOR
