Prepping Weiand Excellerator to go on stroker
B3422w5
Portage michigan
Still needs to get cleaned up, but its pretty much ready to go otherwise.
This is a great intake, ports come very small.....Not so much any more..
Be curious to see some results soon.
Basically taking the top end off my poochy 9.5 ish compression 360. And directly Swapping it onto a 12.5 compression 418. Same cam, heads, carb, headers, etc. only change will be to excellerator from Airgap.
The eddies arent worked much, so not expecting miracles, just hoping for enough to no longer fall asleep before making gear changes
Yep, very good intakes. It'll be interesting to see how your stroker likes it. :thumbsup:
